Info display
Hi does anybody have wiring pin out for info screen connector. Thanks
(20-06-2025, 09:59 PM)Stevie C Wrote:  Hi does anybody have wiring pin out for info screen connector. Thanks
I will check but I don't think the wiring diagrams I have [buried somewhere in the garage  Rolleyes ] went into that level of detail as it was just a ribbon type connector for memory.
Why do you need a 'pin-out' diagram, is something not working on the info display?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
If you mean the centre-of-dashboard screen, there's only 4 wires to it -
Power
Ground
CAN high
CAN low
The Type A and C screens are interchangeable, though features like bluetooth may require coding, and the correct screen and radio.
Way, way more informtion on eg Frechcarforum.
.pdf   Stereo (RD45 MP3) Schematic.pdf (Size: 282.88 KB / Downloads: 7)
.pdf   legende.pdf (Size: 73.37 KB / Downloads: 5)
Is the Frechcarforum. still working , I get the message that its down,
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Seems to be working for me
(24-06-2025, 07:37 AM)brodfather11 Wrote:  Is the Frechcarforum. still working , I get the message that its down,
Seems to be working for me also: https://frenchcarforum.co.uk/forum/viewforum.php?f=3
What browser are you using?
_______________
Not a Citroen  Cry
Just seen your post and tried it and its now working for me by clicking your link
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
