Hello guys.
I have a 2017 B9 I CAN CHANGE GEARBOX OIL BY MYSELF? NEED YOUR HELP HOW I WILL DO IT
Can you do it yourself? You tell me, can you? Smile
Emptying - there's an obvious drain plug on the underside of the gearbox.
Filling - there's a 17/19mm bolt at the RH side of the gearbox end plate.
Refilling, a pump bottle is very useful.
Take off the LH front wheel for easy access.
Get the van level.
Refill using the fill point until oil starts to flow out.
Requires slightly less than 2 litres.
Oil is 75w/80, GL4+, PSA B71 2330.
Lots of yt vids
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
