2016 auto purchase - any advice please
Threads: 22
Thanks Received: 12 in 10 posts
Thanks Given: 2
hI, I have an M59 which is manual and due to a health problem need to get an auto.
I'm considering a 2017
1.6 BlueHDi Feel Edition Multispace MPV ETG6 Euro 6 (s/s) 5dr
(Its a disability conversion which suits us) and 30k miles.
are there any particular issues/weaknesses with the model/age to be aware of?
many thanks
Rob
Threads: 46
Thanks Received: 153 in 123 posts
Thanks Given: 34
21
(27-07-2025, 09:02 AM)Robho Wrote: hI, I have an M59 which is manual and due to a health problem need to get an auto.
many thanks
Rob
Okay so you have an M59, which must be a pre-2008 diesel. Leaving aside the auto box for a moment, do you really need a diesel? The reason I ask is that the modern diesels with all their ad-blue, DPFs etc do not like short journeys, it kills the DPFs really quickly. The fact that this vehicle has done low miles points to the fact that it will have probably only really done short journeys, so you can expect DPF problems soon and all the expense that causes.
Modern diesels are extremely complex to deal with the emissions and because of that are more prone to problems [a lot more than your M59] especially, as I said if you are only going to do short journeys.
Don't get me wrong I really like Berlingos and Citroen Diesels in general [as you can see in my list of vehicles I have owned] but modern diesel vehicles only make sense if you are going to be doing higher mileages, which clearly you are not. Would I buy another diesel Berlingo, no as I no longer do the mileage now I've retired so it doesn't make financial sense either on the fuel cost side or the maintenance costs. I wouldn't even buy the Petrol version as that is a 'wet belt' system and is not really reliable.
I've never owned an auto but reading posts over the years on this forum of people who have, the 'auto' box on the Citroen is not a true auto box at all but more like a semi-auto, again it is a much more complex system prone to faults.
Personally, and I don't know if your finances will allow, if you need an auto and a Berlingo and are not doing high mileages [which I assume you're not as a disability conversion will have a smaller fuel tank] I would go for an electric Berlingo, as that is obviously a true auto and no worries if you are only doing short journeys
_______________
Not a Citroen
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Threads: 22
Thanks Given: 2
Thanks for the thoughtful reply. You are right in that the one in question will likely have done short journeys. The auto is due to my wife having an ankle problem and not being able to operate a clutch. In fact we do cover the miles, hence the diesel and I had read the petrol versions can be problematic. Unfortunately budget is c. £8k which is way off the cost for an electric one.
Threads: 46
Thanks Given: 34
21
(28-07-2025, 09:11 AM)Robho Wrote: Thanks for the thoughtful reply. You are right in that the one in question will likely have done short journeys. The auto is due to my wife having an ankle problem and not being able to operate a clutch. In fact we do cover the miles, hence the diesel and I had read the petrol versions can be problematic. Unfortunately budget is c. £8k which is way off the cost for an electric one.
One other thing to remember about as disability conversion Berlingo is that the lowered rear floor normally means a much smaller fuel tank is fitted, so something to bear in mind, as the range will be nowhere like your existing M59.
_______________
Not a Citroen
Threads: 22
Thanks Given: 2
yes, thanks, in fact ours is a conversion too, so familiar with that one.
Threads: 8
Thanks Given: 305
36
28-07-2025, 10:07 PM
(This post was last modified: 28-07-2025, 10:09 PM by jj9.
Edit Reason: Grammar correction
(28-07-2025, 03:07 AM)Multispacer Wrote: Okay so you have an M59, which must be a pre-2008 diesel. Leaving aside the auto box for a moment, do you really need a diesel? The reason I ask is that the modern diesels with all their ad-blue, DPFs etc do not like short journeys, it kills the DPFs really quickly. The fact that this vehicle has done low miles points to the fact that it will have probably only really done short journeys, so you can expect DPF problems soon and all the expense that causes.
Best advice regarding a modern Diesel vehicle I've seen in a long time.
Threads: 22
Thanks Given: 2
(28-07-2025, 10:07 PM)jj9 Wrote: (28-07-2025, 03:07 AM)Multispacer Wrote: Okay so you have an M59, which must be a pre-2008 diesel. Leaving aside the auto box for a moment, do you really need a diesel? The reason I ask is that the modern diesels with all their ad-blue, DPFs etc do not like short journeys, it kills the DPFs really quickly. The fact that this vehicle has done low miles points to the fact that it will have probably only really done short journeys, so you can expect DPF problems soon and all the expense that causes.
Threads: 22
Thanks Given: 2
Thanks again for the feedback.. in fact decided to buy another brand. Cheers.
Threads: 8
Thanks Given: 305
36
Good luck & happy motoring with your new vehicle.
Threads: 22
Thanks Given: 2
Leaking windscreen or aerial
Yesterday 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
