Upper sliding door roller scraping against body
I've noticed this on almost 2yr old car, it's been happening for some time (probably since new) but haven't figured what it is.
The upper hinge arm is so low that it scrapes against the body, leaving marks (see image). Never damaged, the door is perfectly aligned.
Haven't tried yet, but looking at the mount it seems I can't raise it due to guide holes/nuts (photo).
Can this be adjusted somehow? The door shouldn't be raised as it's already aligned, so it must he just the upper arm. Is the arm angle bad (ie it should be bent/replaced)?
thanks
Attached Files Thumbnail(s)
Replying to myself: looked into it today and indeed it cannot be adjusted, so given that the door is perfectly aligned, it must have been the arm.
If anyone else comes across this:
a) remove the rubber bumper at the end of top rail (8mm hex bolt)
b) remove the two 13mm hex bolts to undo the upper arm. Hold the door!
Remove the arm by sliding it back.
(then close the door so it doesn't fall off)
Then, I slightly (!) bent the arm upwards and re-did everything.
It's perfect now.
hope they aren't so sloppy when it comes to the engines... oh, wait... :-D
Good job well done, the engines , that is another story , they do some great things , others things they do and why they do it , is hard to workout , why cook rubber and other compounds in oil and expect it to last . Huh
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
