Fuel filter change
    Just got a quote to do some work and wondering if I could do some myself?  Not changing the battery it’s fine. Is changing the fuel filter a hard job lads?
Its the most basic tools needed
Getting the filter in and out from under the bulkhead is tight but doable for most people.
Sometimes the primer button doesnt do its job and you have a job to get things flowing again without running the injector system with no fuel in it.
Sometimes it works first time
This guy does good videos
https://m.youtube.com/watch?v=pAQRXPywC1s
Try to get the filter full of fuel before reassembly then attempt to syringe some into the pipework before reconnecting before going to the lengths that he does in the vid
But first Id look at finding another garage -you are paying a lot more than our main dealer would even dare to charge
  • Lively
I know aussie dollars aren't real money, but that fuel filter price seems wrong.
For example, https://www.ebay.com.au/itm/194234106347
The prices are generally screwy. Replacing the filter on an hdi Berlingo is a trivial job in comparison to changing the CV boot.
Thanks lads
(07-08-2025, 06:19 AM)Lively Wrote:  Thanks lads
The main thing to remember with the fuel filter [which I'm sure you are aware of] is to keep the area extremely clean to avoid any debris getting in the filter or associated pipes. The fuel filters I have bought in the past for the 1.6Hdi and 2.0Hdi engines all came with a set of plastics caps to put over pipes as they were removed to stop and contamination of the system.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
[-] The following 1 user says Thank You to Multispacer for this post:
  • Lively
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
