Threads: 31
Thanks Given: 18
Hi lads my drivers window doesn’t work with one touch anymore and it only goes up about 50mm at a time and then you have to pull the switch again. Anyone have this happen to them before and how did ye fix it?
Thanks.
Threads: 0
Thanks Received: 22 in 21 posts
Thanks Given: 24
4
Maybe the adaptation procedure helps. It is described in the owners manual, but roughly this way:
Repeatedly activate the button until the window reaches the top position. Then continue pulling the switch for some seconds. By this it should learn the top position, and auto function would be enabled again.
