Threads: 19
Thanks Received: 31 in 30 posts
Thanks Given: 12
16
..." touchscreen display is showing the functions but touchscreen is not.."
You've got me confused there when looking at your photo.
I must be missing something.
Now a 2019 K9 1.2 petrol.
Threads: 4
Thanks Received: 1 in 1 posts
Thanks Given: 2
Sorry the screen is coming on but when you touch the screen it won't do anything.
Threads: 19
Thanks Given: 12
16
Do the icons on each side, the three on each side, function, i.e. will bring up a different screen?
Is the screen clean?
Threads: 4
Thanks Given: 2
Yes the buttons at the sides work ok
Threads: 19
Thanks Given: 12
16
Maybe it needs to be updated but I really have no idea now.
Threads: 16
Thanks Given: 46
5
My touchscreen started doing odd things like going blank on start up or changing language to French whenever it felt like it. Last service my Cit garage updated it & all good since.
Threads: 0
I had the same problem apparently it was a resistor that drys out in the back of the screen. Had to get someone to do it but didn’t give to much away.
I have the same issue as above..
The display comes on, the side buttons work to select the function options but no touch control..
Can anyone (CB-C9murf?) put me on to the person who does the repair pls..
Similarly, if it's a remove and send away job,, is there a worthy guide on touchscreen removal?
Tia.
Andy
