Threads: 31
Thanks Given: 18
Hey lads just a quick one. How long for your local garage to do the clutch in a b9 berlingo 1.6 hdi? Garage here reckons 10 hours . About $2500 to do it including the clutch kit. Surely that’s not right is it?
Threads: 20
Thanks Received: 9 in 9 posts
clutch kit etc £400 in 2021 in the UK
2009 1.6HDI with AC
The following 1 user says Thank You to magoo1 for this post:1 user says Thank You to magoo1 for this post
• Lively
Thanks Received: 63 in 58 posts
Thanks Given: 2
10
26-08-2025, 08:39 PM
(This post was last modified: 26-08-2025, 08:39 PM by shtu.)
It's an industrial-grade bitch of a job. Access is difficult, some of the assembly is plain insanity.
For example, go look where the starter motor is, then pasue for a moment to consider that there are bolts holding it in from both sides of the bellhousing. Even just reacing the connectors for it are a challenge.
Then pause to consider that there is a bellhousing bolt hidden behind the DPF, so you'll be removing large chunks of exhaust system to reach it.
And so on, and so on.
The following 1 user says Thank You to shtu for this post:1 user says Thank You to shtu for this post
• Lively
Threads: 41
Thanks Given: 129
9
27-08-2025, 07:43 AM
(This post was last modified: 27-08-2025, 07:57 AM by notsofast.
Edit Reason: Added exchange rate
I think Sol posted on here a while back about being quoted a high price for a clutch change on a B9, this was at his local garage, so he went to Mr Clutch or one of those business types, and got a much cheaper quote. I think he said he wouldn't normally use them, but the price difference was considerable, and if memory serves me correctly, I think he was satisfied with the job they did, though it would probably be worth digging out his old thread.
[Edit: This is the thread:
https://www.berlingoforum.com/thread-20818.html - it wasn't Mr Clutch, though it was a guy who specialises in clutches. The price difference between his price (£350 four years ago) and what you've been quoted is massive (AUS $2500 = c.£1250)].
The following 1 user says Thank You to notsofast for this post:1 user says Thank You to notsofast for this post
• Lively
