Hello, 1.6hdi gurus's.
My '06 M59 1.6 HDi runs rough as a bears backside when cold, but after running it at 2000 rpm for the length of a song (say, 3/4 minutes it settles down and runs fine.
I suspected the 7 year old glow plugs, renewed, no fault found.
The glow plug relay, renewed, no fault found.
No codes, no EML, just blue smoke on start up.
It's 19 years old with only 75k on the clock and only does short trips these days, could the cold start running issue be caused by coked up inlet valves that all direct injection engines suffer from if only used for short trips?
Any other suggestions to consider? Like is there an ECU trigger point for activating the glow plug relay, because I've rarely seen the glow plug lamp lit in 9 years of ownership.
Is there a circuit I can jack into to have manual control over the glow plug operation, without blowing the CANBUS's mind?
Is there a known good specialist for walnut blasting in the West Midlands?
Or better still a mobile walnut blaster?
Anyone done their own walnut blasting or other intake valve cleaning on this engine.
Any input welcome.
Any input welcome.
