  • 15 Vote(s) - 2.33 Average
particle filter question
Right, on the 07 1.6 hdi berlingo, there are no sensors on or after the particle filter, why does it need a remap after removal,
Hi, Only thing I can see in procedure is to check that the pressure sensors are working.
Have a look. Confusedalut:
.pdf   Particle filter.pdf (Size: 191.23 KB / Downloads: 12)
mine is a different dpf, it doesnt split and theres no sensor connections on it.
only connections are exhaust in and exhaust out[/align]
It doesn't need a remap as such, although it might help a bit.
What it needs is for it to be deleted from the ECU. If this isn't done you will get fault codes as the ECU will be looking for signals from sensors that either don't exist, or are out of range.
What signals if I don't have any sensors on the dpf
I'm having trouble finding your filter.Confusedcratch:
If you could PM me your Vin No. I should be able to find it. :thumbsup:
Not familiar with this system, sorry didn't notice that yours has no sensor. As an example, some PSA had an indicator that more Eolys fluid should be added, this was linked to the number of times the fuel filler had been opened. Or, you have my nemesis the MAF sensor indicating whether the EGR circuit is working
Ok, this is what's listed for your engine. According to this it has no particle filter only a Catalytic converter (item 10). Confusedcratch:
Have a look. Is this yours ?
[Image: sbosu8.jpg]
I thought only the Mk3 110bhp & later Mk3 90 & 75bhp diesels had dpf?
ya looks like it.
can i remove the cat without a remap?
what power does it say my van is?
thanks for the help
[-] The following 1 user says Thank You to corkgsxr for this post:
  • Rustscrat
Today 05:29 PM
Not able to register
Last Post: Mike
Yesterday 11:03 PM
2011 B9 DPF warning light
Yesterday 10:51 PM
Last Post: Matt Haigh
Yesterday 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
21-01-2025 03:09 PM
Last Post: pondweed
21-01-2025 01:21 PM
21-01-2025 12:41 PM
21-01-2025 09:18 AM
» Replies: 23
Free To Collect From CO14 8LD B9/K9 Floor Mats
21-01-2025 12:43 AM
