Clutch Identification
Hello,
I have an 08 registered Partner Mk2, the clutch is starting to slip so I am looking at replacing it myself.
Firstly, is there a sure way to identify what clutch it might have fitted please? I note several different sizes but as the engine is a DV6ATED4 does that help? Pretty sure its not a dual mass flywheel as its always been a bit snatchy to start off in cold damp weather.
Secondly, any tips or advice on doing the job? Will replace the final drive seals as I remember always having leaks on our old 305's after replacing drive shafts.
Thanks.
https://www.catcar.info/citroen/?lang=en&l=
  This is online parts catalogue , it helps to find part numbers etc.
 Your partner would a M59 equivalent I think as the 08  year is a changeover year.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • 08m59
This is the Peugeot catcar
https://www.catcar.info/peugeot/?lang=en
  • 08m59
M59 unlocking itself
05-11-2025 04:06 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
31-10-2025 03:06 AM
» Replies: 40
