White smoke after fuel filter change
Hi all,
I just did (most of) the service myself for the first time on my 2008 Berlingo/1.6HDi, not much that went wrong besides the glow plugs I mentioned in a previous thread.
However the van kicks out a lot more white smoke and a stronger diesel smell than before, after driving for a while it's much better but it comes back every cold start.
I checked the fuel filter but it seemed fine, no leaks to be seen. Pumping the fuel primer every so often doesn't change much, but it keeps making a crackling noise no matter how long I pump it.
Any tips of what to try? Or just give it a trashing on the highway, this seems to fix a lot of issues with these engines  Big Grin
If you were dealing with glowplugs and it only happens on cold starts then thats where Id return to
Or condensation perhaps -is there water in the filter housing?
(03-10-2025, 05:10 PM)evdama Wrote:  If you were dealing with glowplugs and it only happens on cold starts then thats where Id return to
Yeah the glow plugs was my first thought - white smoke and smell of diesel indicates incomplete combustion, and if it's only when the engine's cold, a glow plug might not be performing its function properly.
Have you checked the new plugs are properly connected? Maybe one isn't receiving any electrical power.
The glow plugs weren't working before that though, even the relay didn't work. The fuel filter was brand new so I doubt water got in that fast.
Strut Top Mounts
Today 07:58 PM
Yesterday 09:30 PM
Yesterday 09:27 PM
Rear seat belt breakage
Yesterday 04:13 PM
removing front strut
13-09-2026 06:10 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
29-08-2026 08:39 PM
