Threads: 59
Thanks Received: 11 in 10 posts
Thanks Given: 49
Am I right in thinking my tyre pressures are sensed with monitors inside the tyre rather than by the ABS system?
Make life easier - go automatic.
Threads: 16
Thanks Given: 46
5
If it’s the same as any other current Berlingo then there are no monitors inside the tyres. It’s done on the abs I think. After you check the pressures you need to touch the car symbol on left side of screen then update the pressures.
