Wire through bulkhead
I have spent ages trying to find an unused hole in the bulkhead of my '23 e Berlingo that has an unused grommet in it.  I can see where the bonnet release cable passes through but the idea of using that is out of the question as far as I am concerned.  It has been suggested there is a grommet behind the passenger wheel arch cover but again the idea of that is out of the question.  It is so frustrating - is the body tailor made for electric Berlingos because there used to be spare holes like where a clutch would be in an automatic?
Make life easier - go automatic. Cool
(30-10-2025, 12:27 AM)John Bilko Wrote:  I have spent ages trying to find an unused hole in the bulkhead of my '23 e Berlingo that has an unused grommet in it.  I can see where the bonnet release cable passes through but the idea of using that is out of the question as far as I am concerned.  It has been suggested there is a grommet behind the passenger wheel arch cover but again the idea of that is out of the question.  It is so frustrating - is the body tailor made for electric Berlingos because there used to be spare holes like where a clutch would be in an automatic?
I'll admit I have no experience of the latest version of the Berlingo but does it not still have the equivalent of a BSI located inside the passenger cabin?
On the previous models that I worked on [an M59 and a B9] a fairly large loom entered from the engine bay into the area where the BSI was located [on RHD cars the BSI was on the driver's side up above the steering rack area. To access the large bung/loom that ran to it from the engine bay required removing the windscreen wipers and then taking off the scuttle cover [about 4-6 torx head screws] Obviously the loom/bung was sealed, so if you do find this location and poke some extra wires through make sure to reseal the area with a good quality weatherproof sealant.
If it is a similar set up to previous Berlingos, you may also find when you take off the scuttle plate there are drains at both ends that get blocked with debris, leaves etc. so if this is the case, take the opportunity to clear out any debris.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Last Post: BigVtwin996
Yesterday 08:25 PM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
