Engine Fan Running
I have a 2014 1.6 hdi (9pf) engine
More often than not when i turn the van off the fanss still running for a bit..sometimes its fast sometimes its slow
No running issues or warning messages
Just clocked 149k and runs well
Only issue which i tihnk is linked on the diagnostic machine well pc with the citroen/peugeot software it says something to the effect
DPF ash content 100% replace- and the eolys isnt being added?
Assume its all linked..can anyone advise please
Rather get an issue resolved than leave it..Still drives and pulls well...fuel economy seems to have dropped a little but could be me Confused
Drive A Berlingo/Partner 1.6hdi 14-Plate Undecided
Just from that info...dpf blocked and eolys pouch empty?
(16-11-2025, 08:42 AM)evdama Wrote:  Just from that info...dpf blocked and eolys pouch empty?
149,000 just right for the eolys to have run out , fan running could be trying regen, with no eolys .
I have heard others say that if you stop the vehicle whilst it’s trying to do a DPF regeneration then the fan will continue runnng in order to dissipate the excess heat.
The Eolys Fluid (PAT Fluid) is added to the fuel tank when you replace the fuel cap (as in after adding fuel). As far as I know this is a magnet and reed switch arrangement.
I.e. there is a magnet in the fuel cap.
If the Eolys Fluid runs out then you should get a warning message and warning lights. AFAIK the level is determined by keeping track of how much has been dispensed and NOT a level sensor.
The Eolys Fluid allows DPF Regeneration (Soot Burnoff) at a lower temperature.
Also, I think, that for a regeneration cycle to complete you need to drive for 5 minutes at above 40 mph once everything is upto temperature. If your usage doesn’t encompass this then it might not be regenerating (cleaning) the DPF.
Relevant page from the (2016) handbook attached.
Attached Files Thumbnail(s)
2016 Berlingo Multispace XTR BlueHDI 100 BHP
2010 Berlingo Multispace XTR HDI 90 BHP
Thankyou all, it'll have to go in to the garage i think and let them sort it out, long gone are the days of me repairiing it, My head can do it..it's all i know from school it's just the body says otheriwse...
Bloody hate anybody else working on my van..except my good old mate who owns his own garage...has exactly the same attention to details as i had when repairing vehicles...something which in this day and age has long been lost...the machine says this sir so it must be right!
Today 10:41 AM
» Replies: 16
Today 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
24-10-2026 08:09 PM
