17-11-2025, 10:37 AM
Hi, just thought I'd like to share a fix for a battery problem I had with my old van.
The battery would let me down frequently in the morning, so I needed to recharge it overnight.
Normally, I might have just stumped up for a new battery, but this time I tried a bit more investigation, namely the good old voltmeter.
It seemed my battery showed a full charge, but when the engine was running, the voltage would spike up to 16, 17, and 18 volts, so I changed the voltage regulator at the back of the alternator in situ for less than 30 bucks. The problem was solved, also some flickering dash lamps sorted themselves out as well.
Just thought I'd share this in case someone was having battery problems.
