  • 11 Vote(s) - 2.82 Average
Brake light issues
The two bottom brake lights on the left and right don't come on when the brake
Pedal is pushed but the brake light above my rear window does. I have checked all the bulbs and have checked fuses. Could this be a problem with the wiring? The Haynes manuel is not making much sense lol
Thanks Lliam
Hi.
If fuses and lamps are alive. Try to check a brake pedal switch using ohmmeter.
I was being stupid. Checked the bulbs in the dark so didn't see the wire that attaches the two filaments that was broken. Looked alright but should of used a torch really. Teach me to look a bit better next time. I replaced the brake switch not so long ago as mine went faulty
Lliam
Hah had the element broke in the brake? Kinda explains why it wasn't working.
Thanks for the giggle. Glad its sorted.
I have the same problem but my bulbs are fine.
The police have put a prohibition notice on my van, even though the third light in the window is working (which I thought was a little bit harsh.)
Any ideas?
Jonathan
(27-09-2010, 02:38 PM)lemsworld Wrote:  The two bottom brake lights on the left and right don't come on when the brake
I had a problem with mine, when I pressed the brake pedal the brake lights came on but by the time I had dashed around to the back of the motor they had gone off again Big GrinBig GrinBig GrinBig GrinBig Grin
(Sorry Liam, couldn't resist that one Hee Hee)
I had the same sort of issue. Lights on all working fine . Brake on the left light went out and all the others were ok. When I checked it was a simple connection issue. The two connections in the bulb holder had been depressed and the spring loaded connecter simply didn't return high enough to make a connection. I just lifted the two conecters up and hey presto.
20-07-2026 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
