Threads: 52
Thanks Given: 87
5
18-02-2011, 02:37 PM
(This post was last modified: 18-02-2011, 06:01 PM by 3rensho.)
Hi all, need some help. I am doing an oil and filter change on my 2010 Mk 3 with an HDi 110 motor. I have the filter and cap out but the filter is still attached to the plastic cap. Is there a fastener that holds it at the top of the cap??? Looks like there is a plastic nut, then a rubber gasket and then the top of the oil filter cap. Any info GREATLY appreciated. PK7478 any advice?? I put the old filter assembly back in for the time being.
Tom
Threads: 80
Thanks Given: 25
pk your such a help........I`m sure we all appreciate your imput greatly.
Pete
Threads: 52
Thanks Given: 87
5
Many, many thanks PK7478. That's good to know. I pulled on it pretty hard but no luck. Will give it another try.
Threads: 25
Thanks Received: 235 in 131 posts
Thanks Given: 44
12
3rensho.
During pulling out it from cap, rotate in both directions.
The following 1 user says Thank You to pk7478 for this post:1 user says Thank You to pk7478 for this post
• 3rensho
Threads: 52
Thanks Given: 87
5
Got all the oil pumped out - works great and got the filter off and replaced. I was just too wimpy trying to pull the filter off. Didn't want to damage anything
Added 3.25l of Total Quartz ineo ecs 5W30 and all is well with the world. Noch mals, vielen Dank PK. Du bist wirklich erste Klasse.
The following 1 user says Thank You to 3rensho for this post:1 user says Thank You to 3rensho for this post
• pk7478
