Horn not working
Had the van for service today and told them the horn wasn’t working.  All he could tell me was there is constant power at the horn and when you push the horn the voltage goes up but the horn is still not working. I imagine there shouldn’t be constant power there until you actually push the horn. I have no idea about wiring and will have to take it to an auto electrician but just said I’d ask here in case this makes any sense to anyone. Any help appreciated
2008 B9 1.6 turbo diesel
(16-12-2025, 10:15 AM)Lively Wrote:  Had the van for service today and told them the horn wasn’t working.  All he could tell me was there is constant power at the horn and when you push the horn the voltage goes up but the horn is still not working. I imagine there shouldn’t be constant power there until you actually push the horn. I have no idea about wiring and will have to take it to an auto electrician but just said I’d ask here in case this makes any sense to anyone. Any help appreciated
Theres plenty of content on the subject if you do a forum search.
Mine was sorted with a replacement fuse but if you have to dig deeper theres corrosion/ furring in the fusebox,bad earth from the steering wheel and bad connects on the horn to investigate.
  • Lively
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
