19-12-2025, 06:48 PM
Hi all,
I did a quick search of the forums but didn't find anything conclusive relating to this issue so decided to start a new thread.
Our N/S brake light keeps failing. Every other bulb in the cluster, and all of them on the opposite side are fine.
The bulb still works, it's just that over time as the vehicle moves and bumps around, it causes it to have a poor connection with the cluster. With someone holding their foot on the brake I can wiggle the bulb into a position where it works again.
Wedging a piece of plastic in between the bulb and the holder seems to help for a bit, but eventually we're back to it not working.
We even replaced the cluster with a new one to see if that helped, and changed the bulb, but after a while the problem came back.
Has anyone else encountered similar? I find it most odd that the problem keeps happening in the same place, despite changing all the parts. I'd say it was a design flaw but the othet side is ok!
Thanks!
Thanks!
