Threads: 43
Thanks Received: 414 in 371 posts
Thanks Given: 137
33
Is the heater motor running ? The resistor on the heater motor sometimes packs up, easy to replace. There are a lot of posts on here about it and how to replace them.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Thanks Received: 63 in 58 posts
Thanks Given: 2
10
24-12-2025, 06:26 PM
(This post was last modified: 24-12-2025, 06:31 PM by shtu.)
On mine, it was a combination of a mostly-seized motor, which in turn caused the resistor to fail. The first hint was that the blower didn't seem to do much unless on 3 or 4.
Neither are massively expensive to replace (used motor, new resistor), and aren't difficult either. Take the accelerator pedal out for access.
If you need to buy a new resistor (especially a cheap ebay one like I did), look -closely- at the base of it. It will probably need some minor modification to make it fit.
Threads: 59
Thanks Received: 11 in 10 posts
Thanks Given: 49
I went along the lines of changing things economically and I changed the resistor - nothing. What a game to get to though. Maybe I should have started with the motor. I suppose if the car was on a lift it would have saved me having to be a contortionist. I took the fan out and it would not respond to power so I fitted a new fan costing £19 and that solved the problem. Again I had to do my contortions but at least the accelerator pedal stayed in place!
Make life easier - go automatic.
