Threads: 39
Thanks Received: 4 in 4 posts
Thanks Given: 21
K9 swb 1.5d regularly serviced.47k miles. Not noticeable on heavy acceleration. No DTC reported by head unit. Any clues what is causing this and a fix?
2021 Berlingo Flair M (K9) 130D
I.T. is there to help, but unforgiving if you make a mistake
Threads: 17
Thanks Received: 5 in 5 posts
All the time or just when cold or hot ?
Threads: 39
Thanks Given: 21
It seems to happen all the time when acceleration is gentle building up revs hot or cold say in heavy traffic. But not noticeable if accelerating harder say pulling out right to cross a junction or moving away smartly at traffic lights.
Threads: 39
Thanks Given: 21
I've had the car from new and I don't recall it happening when new. It might be since the last firmware update I did a couple of years ago. I think there is a new update to it issued earlier this year. I might install that.
Threads: 8
Thanks Given: 305
37
I had a hesitation exactly like you are experiencing on a Renault 1.9 Dci a few years ago.
Turned out the hesitation was the EGR valve opening which reduces the power of the engine, it was only noticeable if you were accelerating gently from rest..... Blanked the EGR valve off and the hesitation was gone.
Cheers.
