[Steering & Suspension] Berlingo rear suspension
Hi, I have a 2014 Berlingo Wheelchair access Vehicle which has been lowered to get a wheelchair in. Underneath is a gas strut to help with the lowering and lifting of the wheelchair ramp. Thanks to my councils obsession with speed bumps the gas strut has been changed twice and has just gone again after hitting Speed bumps when going over very slowly.
Is there anyway of lifting the rear slightly to get over the damb things other than expensive air assistance
Graham
My WAV Berlingo has coil spring spacers installed.  A while ago I noticed one was not fitting just right so I pulled them both out . Two weeks later I had to reinstall them as it made the rear of the Berlingo too low., not like yours but when reverse parking the exhaust was hitting the kerb which it didnt do before.
Found a video which shows how to fit but not on a Berlingo and he makes it look easy which on mine it wasn't. Had to disconnect the rear shockers and drop out the springs.  It shows how they fit and what they do.
https://youtu.be/C6z6CMJGSWA
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(30-01-2026, 05:31 PM)brodfather11 Wrote:  My WAV Berlingo has coil spring spacers installed.  A while ago I noticed one was not fitting just right so I pulled them both out . Two weeks later I had to reinstall them as it made the rear of the Berlingo too low., not like yours but when reverse parking the exhaust was hitting the kerb which it didnt do before.
Thanks for that will have a look
Graham
Users browsing this thread: 2 Guest(s)
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
