Rear seat belt breakage
Hi I have just experienced a really weird problem. I noticed a persistent knocking coming from the rear seat area so stopped to take a look. It was the rear l/h seat belt buckle banging against the trim, so hey that's ok, but on further inspection the buckle and part of the belt came away in my hand having been completely severed! Thought i'd check the r/h one and to my surprise that was exactly the same! It appears both had worn away where the belt enters the trim. I haven't used the belts for years (no back seat drivers/passengers). Has anyone come across this before? Huh
We have a local garage with a rat infestation- they chew u vehicles left over the weekend.
(02-02-2026, 12:22 PM)theflyingpig Wrote:  Hi I have just experienced a really weird problem. I noticed a persistent knocking coming from the rear seat area so stopped to take a look. It was the rear l/h seat belt buckle banging against the trim, so hey that's ok, but on further inspection the buckle and part of the belt came away in my hand having been completely severed! Thought i'd check the r/h one and to my surprise that was exactly the same! It appears both had worn away where the belt enters the trim. I haven't used the belts for years (no back seat drivers/passengers). Has anyone come across this before? Huh
Funny, I have just put seat belts into the search forum because I have just found my rear passenger side seatbelt in exactly the same condition! Going to check the other side now…… need to locate at least one replacement….
One local garage is infested and the rodents chewed a hole though a door lining.
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
17-10-2026 05:41 PM
