[Warning Light] Urea light flashing after NOx module replaced
So i had the dreaded NOx failure with no communication error Check engine light on, Urea light on.
After I replaced the module and cleared the error now I no longer have the error (check engine not light anymore) but the Urea light is flashing, no error appears on Diagbox.
Do i need to do some calibration or something? Diagbox reports about 11L of adblue in tank, eolys level is good.
PS: here is how my failed NOx module looks inside...
Attached Files Thumbnail(s)
If you like gaming visit GameForest
solved the problem! i used diagbox, repair menu, then engine ecu, then replacement parts, nox sensor replacement, it coded something, then turned ignition off for 30s, then bam!! no flashing urea light!
(21-03-2026, 12:32 PM)deejay_xb Wrote:  solved the problem! i used diagbox, repair menu, then engine ecu, then replacement parts, nox sensor replacement, it coded something, then turned ignition off for 30s, then bam!! no flashing urea light!
Good work, especially coming back to post the answer for everyone else. Big Grin
Mileage
Yesterday 04:33 PM
eolys
Last Post: magoo1
19-05-2026 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
