Threads: 43
Thanks Received: 412 in 369 posts
Thanks Given: 137
33
An MOT advisory fault was a cloudy headlight , so I got a Holts Headlight Restoration Kit. It did the job and after 2 months its still clear even though I didnt coat the finished job with the sealer provided in the kit , will get round to it eventually,. It was easy to do with a small drill at low revs.
It also cleaned up the solar panel on a garden ornament quite nicely.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 81
Thanks Given: 165
20
30-03-2026, 04:02 PM
(This post was last modified: 30-03-2026, 04:26 PM by evdama.)
As a coincidence Ive just bought a Cerakote kit
Allegedly very long lasting.
My lamps are just starting to go champagne colored at the tops so hopefully it wont be to difficult.
Id like to have the lamps off to do it but Its major hassle getting the bumper off when your garge is the street outside the house
I also have to find a way of keeping the laquer dust and moisture free for 30 mins sfter application
As multspacer says they are all pretty much the same
You can get the sealer on amazon and 3000/6000 abrasive from paint shop suppliers.
Its then up to you how much effort you put in.
My van is so beaten up I really wouldnt bother but the mot inspectors at my chosen garage are the prissy sad mummys boys who spend all weekend detailing their car and seeing mine gets rhem quaking in their trainers.
They think they might catch something off it.Ive spent actual money on paint restorer and polish.
Those two items cost twice the price of an electric paint polisher OMG
• BER-LINGO
Thanks Received: 3 in 3 posts
Thanks Given: 5
Yes was advisory on my MOT as 'product on lens'. Not product numpty, its wear n tear, but knew they needed doing. Strangely, one is a lot worse than the other which might suggest one lens might been replaced at some point in the past.
lmao evdama... ooooh champagne coloured??... who you kidding??!! ha!
Thanks Received: 63 in 58 posts
Thanks Given: 2
10
I did use a Holts kit, plus some additional abrasives. I found the original top layer on mine VERY difficult to cut through.
I also didn't bother with topcoat, though in the Holts kit it isn't a clear laquer, it's more like a spray on silicone, and the instructions state it's to be reapplied every few months. If they ever do fade I'll resand them and use laquer after the 3000 grit stage is finished.
I'm sure that Project Farm bloke did a comparison of a load of kits a while back.
The following 1 user says Thank You to shtu for this post:1 user says Thank You to shtu for this post
• BER-LINGO
Threads: 81
Thanks Given: 165
20
Mine will have to be gust ,dog and malevolent child proof too....
Thanks Given: 5
Do you need a buffing machine?? Theyre expensive!
Threads: 81
Thanks Given: 165
20
