[Brakes] No brake and number plate lights are working
I got no brake light at all ,left right top not workimg and no number plate light also.
I check fuses and they are okay.
Do a faulty brake light switch also affect the numberplate lights ?
Any idea what could be wrong
Berlingo mpv 2019
(26-04-2026, 01:55 PM)mikeh79 Wrote:  I got no brake light at all ,left right top not workimg and no number plate light also.
Berlingo mpv 2019
No, brake light switch would not affect number plate lights.
Are you sure it is not just all the lamps out?
The number plate lamps are well known to fail and they are a but fiddly to replace.
Do the normal rear lights work? Is it just the brake lights? Check the connectors on the rear of the light clusters, as brake lights are higher power, I had one of the connections burn put on my Berlingo.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
The normal rear lights work, i switches those with brakes lights since they are same type and same think.
I would also check the bulb earth connections with a multimeter. Make sure you use a good grounded earth connection to the vehicle metal body.
Have you had any luck? I find that the number plate bulbs fail frequently, and the high level brake light fails sporadically, but find both a relatively easy swap. I'm yet to have the side brake lights fail, touch wood.
Mileage
Today 04:33 PM
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
