Threads: 20
Thanks Received: 60 in 52 posts
Thanks Given: 19
06-06-2012, 08:32 PM
(This post was last modified: 06-06-2012, 09:50 PM by PeteA.)
No A/C on mine so I assume it'll be a pressed steel job! Its just arkward now because the vans my only transport so I cant have it off the road for long. Just need to find out what size drain plug I need now...
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free
Threads: 32
Thanks Given: 13
I wrecked my thread about 12 to 18 months back and thread locked in the Femco drain plug and posted the alternative theory on here and it was a bit of an experiment at the time to see if it was a solution.... It's worked. no leaks and dropped the oil several times and no issues at all!!
Great product and if you use permanent thread lock, it stays in there!!
The alternative is helicoil. No need to fit a new sump.
Threads: 63
Thanks Given: 410
Why not just drive the vehicle to the local engine remanufacturer or engineering workshop, tell them what has happened, let them drop the oil and rethread the sump in situ????
Threads: 32
Thanks Given: 13
Cost? It's probably £80+ to helicoil the sump and then oil change etc.. then it's need doing right so there's no crap left in the bottom of the sump.
Obviously much cheaper than replacing sump but for a bust thread it cost me £30 ish and then future oil changes are so simple with the drain plug.
Threads: 32
Thanks Given: 24
Sorry I didn't credit you Tucker. I couldn't remember who had the original idea that I also used.
The following 1 user says Thank You to Coco for this post:1 user says Thank You to Coco for this post
• tucker
