Threads: 6
Thanks Received: 1 in 1 posts
Thanks Given: 7
08-05-2026, 04:54 PM
(This post was last modified: 08-05-2026, 04:56 PM by redhat.)
Changed brake fluid / bled brakes on my M59 '07 Desire (85k) during routine service initially using pressure bleed kit and noticed pinhole spraying brake fluid from middle of top of plastic brake fluid reservoir. Is it ok for this hole be sealed with brake fluid resistant adhesive (or should reservoir be better replaced) - or is it actually not a hole but a pressure relief/equalising breather vent that should be left free?
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
There is breather hole in the brake fluid tank cap , if its not coming from there there is something wrong
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
21
Surely if its a pressure relief it should have some sort of valve or grommet not just a hole as that would potentially spill fluid or allow moisture into the system.
You could plug it with a small self tapping screw.
A jobsworth mot inspector might take exception to a repair though however well done.
• redhat
Threads: 6
Thanks Given: 7
I glued it closed in the end..
Threads: 81
Thanks Given: 165
21
(08-06-2026, 09:39 AM)redhat Wrote: I glued it closed in the end..
Good
We wont tell anyone
Just need your bank account number and password.
