Rattling calipers
Morning.
We have a M49 Romahome. Over rough ground the calipers rattle. There is slight movement when the brakes are off which I know is normal but there isn’t any visible way to attach any kind of anti rattle spring to them. Has anybody found a Solution to this?
Are the pad springs properly fitted?
Not sure there should be any "movement" other than being able to slide the caliper along its pins with the pads out.
Are you sure is not worn drop links
Thanks for the replies. Had a look at it which was interesting doing it on campsite! The pads springs weren’t flat they were poking through the hole on the caliper.
Alll good now!
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
