Hi Ctek chargers can be used connected to the car battery whilst it's still connected to the car's electrics. Older batteries can be desulfiated using creks recovery mode however I read that the charger can produce up to 16v in this mode.
Two questions:
1) Does anyone know if that high a voltage will damage anything?
2) Has anyone used the ctek in recovery mode whilst the battery is connected to the car?
2021 Berlingo Flair M (K9) 130D
I.T. is there to help, but unforgiving if you make a mistake
As per CTEK, the recond mode should not be used for AGM batteries. Check if your battery is of that type.
https://ctek.my.site.com/faq/s/article/H...9594652697
I'd rather not use it on battery connected to the car anyway. The strong pulsation might confuse the car inbuilt battery management.
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
