[Brakes] Reservoir tank
Hi I'm having a right mare trying to find a replacement brake reservoir tank  part number 4635 74 does anyone know where I can find one of these or are breaking a berlingo with this part any help would be very much appreciated
Attached Files Thumbnail(s)
(25-05-2026, 01:52 AM)Stevie3393 Wrote:  Hi I'm having a right mare trying to find a replacement brake reservoir tank  part number 4635 74 does anyone know where I can find one of these or are breaking a berlingo with this part any help would be very much appreciated
You mean like this one? https://www.borderpeugeotspares.co.uk/pr...-s-4635-74
Looking at that listing, it was also fitted to the Citroen ZX of which there are not many left on UK roads now, so if you are trying to source a 'used' one then maybe look around for ZX in breakers.
From memory, the early M49 Berlingos used quite a bit of kit that had previously been used on the Citroen ZX.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
[-] The following 1 user says Thank You to Multispacer for this post:
  • Stevie3393
Thanks very much for your help that is spot on i really appreciate the help thanks
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
