Fuel pump problems
Hi. I have had to change fuel lines on my 2006 Berlingo 1.6 hdmi, including all the quick release lines and the hand primer now I do not seem to be getting any diesel supply from the tank. I undid the two connector above the timing belt and turned on ignition and there is no fuel coming out. I need to test the fuel pump but cannot find any information on fuses/relays or any wiring diagrams to help me , I have downloaded Citroen service box sedre but even that does not give me the info I need. Can anyone on here point me in the right direction for this info. Thankyou
Does it have a fuel pump in the tank? .
IIRC the early models relied on the injector pump to pull fuel from the tank, and the hand primer to help when bleeding the fuel system. So if you have a hand primer then you dont have a fuel pump in the tank , no need for it .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • peteb5313
This got me wondering too
The hand primers have a reputation for somtimes being reluctant
Ive seen videos of them needing a suction pump or syringe to get them to play ball after a filter change.
Cranking the engine with a dry injector pump isnt advisable.
  • peteb5313
Had a similar problem on my 2008 B9 1.6Hdi, in that there was no fuel coming through after replacing a split pipe, even after using the hand primer numerous times. Resorted to using a large syringe as mentioned by @evdama in his post to initially get fuel flowing and even then, still needed to use the hand primer a number of times to get things going properly.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
[-] The following 1 user says Thank You to Multispacer for this post:
  • peteb5313
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
