New belingo
Hi there looking to get a mutispace xtr or a tepee outdoor
Am i right thinking the 2010 -2014 are the same engines etc just the 2014 has more up todate stuff ie parking sensers  .
Iv seen a few 2010s with lower millage then a 2014 but iv avoided them as was looking for a newer car .
Also should a 2015 be avoided as a worse engine , ad blue etc .
Any help info before i buy the wrong one
16v engines can be more problematic than 8v
Ageing vehicles begin to show up electrical issues so dont make choices based on better equipment levels
(27-06-2026, 11:03 AM)John doe Wrote:  Hi there looking to get a Mutispace XTR or a Tepee outdoor
You need to add some extra criteria to your list before getting more recommendations.
For example are you after a petrol or diesel? Are you going to be regularly driving into any ULEZ areas?
What kind of mileage are you looking at doing per year?
What is your budget?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Diesel motor , outdoor or xtr wont be doing many trips if any near london so ulez not prob .
Would prefer 2012 up to 2014 to avoid the 16v and the ad blue.
I would prefer the 110hp over the 90 for more power if needed.
Car will be used realy as a fishing motor on weekends and for my dogs . I have a motoway 2 mins from my house and can use that to get a2b and to open her up to clear her lungs .
Looking up to £4000 - £5000 .
It seems you already know what you are looking for so just to add to your thoughts...............I have a 2016 Peugeot Partner Tepee adblue model. Done 86000 miles and have just fitted a brand new adblue tank unit at a cost of £600 including MY own labour. All working good now.
Now if you do your sums it works out better to own an adblue model from this era:
Road tax is only £20 a year and if you multiply that by 10 years is only £200 in total. Now compare that with an earlier 2012 to 2014 model. How much is the road tax per year? Maybe about £200??? So now multiply that by 10 years so could be £2000???............I would say don't ignore the adblue models from that time.
(29-06-2026, 08:46 PM)John doe Wrote:  Diesel motor  , outdoor or xtr wont be doing many trips if any near london so ulez not prob .
Things to watch out for. Any of the post 2010 models can be problematic, if you do not do regular longer journeys, as the DPF [Diesel Particulate Filter] can clog and can be expensive to replace. If you do a regular motorway journey, it should not be a problem. So when buying a low mileage might seem a better bet but not always, as just short non-motorway journeys can lead to DPF problems.
You state you want to avoid the AdBlue system on the later vehicles but you do not mention the Eolys system which was on earlier models and can be even more problematic, in that early models that used it suffer from punctured Eolys bags and when the fluid runs out it is not really an easy DIY job to replenish and reset.
In case you didn't know the PSA group used the Eolys system on a number of their earlier models before AdBlue became a thing, to make their diesels comply with emissions. There are some Berlingos that have both Eolys and AdBlue
https://www.carboncleanco.co.uk/2026/03/...r-need-it/
Do a search on 'Eolys' on the forum and you can see many reports of problems with that system, probably a lot more than AdBlue
It it were me, with your requirements and you want to avoid both Adblue and Eolys go for an early 2008-2009 Berlingo Multispace XTR, as in those years, the euro IV diesels did not have either a DPF or Eolys/AdBlue
I had a 2008 Berlingo XTR which had neither and it gave great service and I would still have it now, except for being on the edge of London ULEZ with family living inside and my job [at the time] being just inside the ULEZ area. I regularly got 55+ MPG and was just a really practical vehicle used for everything.
Don't get too hung up on the 110 vs 90 HP version. Mine was only a 90HP and had more than enough grunt, to go along the motorway completely loaded up with the entire family and camping gear on holidays all around Europe.
Same goes for things like parking sensors, with the box van type shape, I never really thought I needed them as good visibility all around plus the flat back end means it was very easy to park.
Things to avoid [in my opinion, others may have different views] The auto gearbox, as it's not a real auto but more like a semi-auto, so adds complexity. Any WAV converted vehicle as these often have the fuel tank replaced with a much smaller one, so reduces range on vehicle.
If you are going to do a lot of long journeys, then consider a Berlingo XTR with cruise control as that was the only thing extra I would have liked on mine for long trips.
Finally, I noticed you stated you are going to use it for transporting dogs around, a cheap recommendation for the rear boot space is the large rubber mats, that are sold regularly in both Lidl and Aldi for about £6 you can get a rear rubber mat that exactly fits the rear of a B9 Berlingo. An old post of mine below but noticed they were both still selling the same mats this year when doing car stuff.
https://www.berlingoforum.com/thread-15402.html
_______________
Not a Citroen  Cry
Thanks everyone for info been loads help and a lot i did not know evan after looking into things . .
Earlier post say to avoid the 16v thats why i said 2012 upwards and was told to avoid the adblue engines as have lot probs with cam chains etc and the adblue system . , was told older engines was far better ones as long as had the cam belt and water pump been changed and serviced reg with right oil . . I did not know they had a earlier Eolys system  on the 12 -14 plates 2 be fair , i dont mind working on erm so i could easy replace bag or tank self then get it flashed ..
Thanks for info on boot mats that and a front seat guard would been first thing buying for it for dogs .
Last Post: wbchevron
Today 07:34 AM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
