Is it only 22 reg owners who are getting recall letters? Mine is a 2019 and not had anything ..
They were doing it in order working forward, my 20 reg was done over a year ago.
Suggest you check with a dealer
2020  1.5 Blue HDi 130 Berlingo XTR
2009  1.5 Diesel Peugeot Partner
2007  1.5 Diesel Berlingo Desire
2003  Petrol Berlingo
(08-09-2026, 11:27 AM)littleowl Wrote:  Is it only 22 reg owners who are getting recall letters?  Mine is a 2019 and not had anything ..
Just for clarity the 7mm timing chain recall is for the 1.5L (1498cc) diesel engine.
A 2019 could have either that or a 1.6L (1560cc) diesel engine which is unaffected.
There are a couple of websites that might help.
You can check for a recall here …
https://www.stellantisandyou.co.uk/service/recall
And there’s lots of information here …
https://www.citroen.co.uk/owners/citroen...ation.html
Including details of a dedicated phone line 08009179285.
2016 Berlingo Multispace XTR BlueHDI 100 BHP
2010 Berlingo Multispace XTR HDI 90 BHP
Had the software update done on Monday. When I checked the update it had this error code P06B8-04 Engine Management ECU fault and it is no longer possible to access live data. I presume the update has corrupted the ECU memory. Booked it back in next month to let them try and do the update again. I will also ask them to print off some live data just to make sure they can access it. Anybody else had this issue, Citroen say it is a known fault after sometimes doing an update. Worrying thing is unless you scan for fault codes and try to access live data unlikely you would know of this issue until a problem arising later and you are hen told it might need new ECU.
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
