Wink
Hi all.
Just after some advice here as not wanting to spend 100's pounds to find the issue.
175k miles, upon starting van from cold seems a little rough on idle, little blue smoke, once warm its fine.
The most annoying thing I am trying to find the solution too is when driving the van am getting a exhaust fumes smell all time when driving.
I have had so far the following done.
EGR VALVE REPLACED
GLOWPLUGS REPLACED
INJECTOR SEALS REPLACED
REAR EXHAUST GAS OX HEATER AT REAR OF ENGINE REPLACED
I am thinking maybe a fault within the exhaust itself but does not sound like there is any kind of exhaust blowing, maybe the front lower flexi pipe?
does any one have the same van and have or had similar issues please and maybe can advise please as its driving me mad.
thanks
all.
Rear door seals ok?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(05-08-2026, 03:14 PM)brodfather11 Wrote:  Rear door seals ok?
Yes, smell coming in via front vents.
Could it be a failing turbo?
Turbo is fine
Then maybe it could be the maf, mas air flow sensor?
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
