Threads: 4
Thanks Received: 1 in 1 posts
Every time I get in the van and out the key in the ignition I receive the message “energy economy mode activated” it also comes up on the touchscreen and says it will now power off. I cannot start the vehicle of do anything.
Any know what tends to cause the vehicle to get stuck in this never ending shutting down mode.
The vehicle has a brand new charged battery installed a day ago as thought that would solve the issue as the van has been sitting a while.
Threads: 83
Thanks Received: 397 in 340 posts
Thanks Given: 179
21
If no other solution I've seen a YT? Vid for another issue where he disconnected the battery and left it for hours with the lights and ignition switched on to drain out any capacitance
Might be worth a try?
Threads: 41
Thanks Given: 130
9
Could the BSI not be recognising that a new battery has been connected, and if the old one had discharged maybe the BSI is still trying to preserve power supply? How much time do you get before the system shuts down? I often get the 'energy economy mode activated' message on the touchscreen, but then nothing happens and it disappears. Could you use the touchscreen to quickly navigate to a way of getting out of the shutdown mode?
