1.6hdi starting problem
I had a major problem with 2013 1.6 hdi B9.. started fine when cold but once up to temp.. forget it.. had to use quickstart spray every time...  was told low compression needs rings...  crank position sensor , MAS etc...  but it goes well, no smoke. smooth . good power..  only done 350k km...  Some one plugged in and said I had a weak #3 injector...  so I made inquiries and was told a leaky injector could cause this problem as pressor fails to build up, cause diesel thin dramatically when warm?   I ordered an injector from China..  $100..and made a prayer..  changed #3 counting from flywheel...  and now it starts with a flick on the starter hot or cold...  what a pleasure!
Well done, isn’t it great when you find the solution.
good reference
One thing after another
Today 10:56 AM
Today 08:44 AM
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
