  • 14 Vote(s) - 2.21 Average
disable immobilizer
Right here is whats going on,
I changed all the locks on my van and i came to the ignition barrel There is a immobilizer well as this is a new barrel and key. well it wont run
is there any way i can disable it?
Multi-trader i will do it all
Try taping the old ignition key under the steering column next to the switch.
If this doesn't work, it may be that this is ECU related.
Would say if you have fitted a new,imobiliser antenna ring at the barrell you would need to get it linked to the ecu as the system is not a plug and play system.
Hi, have a read of this. Confusedtudy:
http://www.berlingoforum.co.uk/showthread.php?tid=2532/
:thumbsup:
Back pain / ache
Last Post: jw4821
Yesterday 06:23 PM
Indicator/lights Stalk
Yesterday 04:55 PM
2011 B9 DPF warning light
Last Post: IKUN
Yesterday 04:51 PM
24-01-2025 04:48 PM
Last Post: BrianS
24-01-2025 01:58 PM
» Replies: 24
Drop in fuel economy
Last Post: Andhall
24-01-2025 09:21 AM
Not able to register
Last Post: Mike
22-01-2025 11:03 PM
Last Post: Matt Haigh
22-01-2025 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Last Post: pondweed
21-01-2025 01:21 PM
