Facia panel removal....anybody know how?
Threads: 4
Thanks Received: 3 in 2 posts
Thanks Given: 11
Hi All,
It's that bit of facia with the window switches on and in particular the 'round blanks'. I would like to remove one of these and put in an additional cigar lighter socket for my satnav rather than trail the lead down to the fitted sockets. I obviously need to remove this small bit of facia but how?
I've lots of experience with classic cars but when it comes to the modern car and plastic I'm not so good. Any advice much appreciated.  cratch:
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
Hi, Is this any use?
facia removal.pdf (Size: 245.72 KB / Downloads: 332)
 alut:
2006 2.0hdi 600 with bench seat.
Threads: 4
Thanks Given: 11
(09-06-2012, 01:10 PM)Rustscrat Wrote: Hi, Is this any use?
Thankyou, That's a real help alut:
So basically from what I can see, I just go straight to this small facia and prise it off? Do other folks agree with this and is there a trick....before I damage the plastic fixings?(something I'm quite good at! illyme
alut:
Threads: 75
Thanks Received: 1,310 in 1,140 posts
Thanks Given: 223
164
yeah looks like it just pries out mate, use something softer than the trim piece so you dont damage it, or find a small sucker from something and try using that to dislodge it.
• jobberwock
Threads: 4
Thanks Given: 11
(10-06-2012, 09:58 AM)Zion Wrote: yeah looks like it just pries out mate, use something softer than the trim piece so you dont damage it, or find a small sucker from something and try using that to dislodge it.
Thankyou and I've done it! Put some gaffer tape around the perimeter of the facia and used several dinner knives to slide in(carefully avoiding the management indoors!). Eventually it came off but did damage one of the three lugs on the top but that doesn't show and hasn't affected the refitting.
Don't think it will take a cigar lighter though. Not a lot of room and there is only a small square hole at the back of the blanking.
Back to the drawing board.
Threads: 75
Thanks Given: 223
164
you may be able to fit the socket under the MFD tray. If you have the depth to take your ciggy socket then a hole saw could be used to make a neat fitting point for one. What about pulling another rubber capped one (like the 2nd one in the centre console) from a scrapper and fitting it there? Or take the lead down into the edge of the MFD tray and down behind the whole fascia, emerging in the clutter box at the bottom....then into the normal socket.
• jobberwock
Threads: 4
Thanks Given: 11
(10-06-2012, 12:12 PM)Zion Wrote: you may be able to fit the socket under the MFD tray. If you have the depth to take your ciggy socket then a hole saw could be used to make a neat fitting point for one. What about pulling another rubber capped one (like the 2nd one in the centre console) from a scrapper and fitting it there? Or take the lead down into the edge of the MFD tray and down behind the whole fascia, emerging in the clutter box at the bottom....then into the normal socket.
THANKYOU. MFD tray suggestion is favourite at the moment. I'm gonna think about it. Am I the only one who is irritated by the satnav trailing wire?
Threads: 75
Thanks Given: 223
164
nah mine annoys me too but I haven't decided where to fit it yet, I may end up putting the wire behind the fascia panels so no extra holes needed, just unclip the mfd tray and slacken the main fascia, then feed the power cable for the sat nav down the inside of the trim so it just appears from the edge of the mfd tray - file or cut a small notch in the edge so the tray sits ok. That way the 12v ciggy plug will lie in the crap tray at the bottom - hidden until needed.
• jobberwock
Threads: 4
Thanks Given: 11
(10-06-2012, 01:22 PM)Zion Wrote: nah mine annoys me too but I haven't decided where to fit it yet, I may end up putting the wire behind the fascia panels so no extra holes needed, just unclip the mfd tray and slacken the main fascia, then feed the power cable for the sat nav down the inside of the trim so it just appears from the edge of the mfd tray - file or cut a small notch in the edge so the tray sits ok. That way the 12v ciggy plug will lie in the crap tray at the bottom - hidden until needed. Thanks ....that's given me an idea ! Cheers
Threads: 0
have to send this to be able to download the answer in the top
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
