  • 12 Vote(s) - 3.42 Average
Aux drive belt broke, now not starting :|
My 1999 berlingo van suffered a broken auxillary drive belt last week, i've fitted a new one today but now the engine will not start, ive checked the fuel lines for air and all seems fine, also tried bump starting it.
is it possible to have flooded the plugs from turning the engine over too often?
The starter seems to turn the engine over fine but it will not fire up.
Also any idea if a broken belt could cause these problems in the first place?
Did the belt get stuck in between the crank pulley and the cambelt cover?
Have you had the cam belt cover of to check its not slipped or shed some teeth.
yes it did get stuck around the back of the crank pulley and was a pain to get out, have not had a look at any internals yet but will do.
edit: the new belt turns fine when the engine is being turned over by the starter, and there are no odd noises, just no firing.
Just thinking if the cam belts jump a tooth or 2 when it got stuck. Might be wrong, but think if its slipper even a couple of teeth then the timing will be out.
Take the cambelt cover off and turn over by hand to see if any teeth are missing then see if the marks/holes line up on all the pulleys.
It will turn over on the starter as the starter doing all the work.
One thing after another
Yesterday 05:02 PM
Yesterday 10:41 AM
» Replies: 16
Yesterday 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
