  • 15 Vote(s) - 3.73 Average
More umpf required
Anybody come up with any ideas to squeeze a bit more umpf from a 1.9 diesel, she's sluggish to say the least....
Its probably far easier and cheaper to replace it with a 2.0 or 1.6 hdi. Don't mean the engine, the whole vehicle.
If only i'd known that before i bought her!!!
(09-06-2012, 02:41 PM)800HDI Wrote:  Its probably far easier and cheaper to replace it with a 2.0 or 1.6 hdi. Don't mean the engine, the whole vehicle.
Guessing you could alter the feuling and improve the exhaust flow abit with a de-cat, but as said for any big gains XUD/HDi is the way forwards Smile
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
I don't think the 1.9D does umpf , mine won't go any faster even on Super unleaded Confusedcratch:
I've squeezed a bit out of her with a de-cat , improved cornering with alloys and lower profile tyres but at no point would I say umpf has been achieved Big Grin .
What about a ecu remap if thats possible-Pedal Box from http://www.diesel-performance.co.uk and get £50 discount using autoexpress discount code ?
Alas, it seems they only do it for 1.6.
Did you not go for a test drive ? Diesel's are workhorses not racehorses.
be happy with it the 1.9 is a bloody good engine and with not much else that regular oil changes ive seen them hit 300k
Ok, it is possible to get more umph, but it involves some spannering on the plain 1.9d and is limited.
1. drill out all the little blanks in the grille - in front of where the air filter feed is. Cone filters are sh*t so just fit a k&n panel filter and make sure the airbox is tightly clipped & sealed afterwards - makes a horrible drone otherwise.
2. Good exhaust condition is necessary, not a sports one but a tightly sealed oem one with no leaks (you lose bottom end torque with a leaky exhaust)
3. Find out what injector cc is currently fitted and fit larger injectors (next size up) - the only caveat on this mod, which will produce a big power gain - is you can't increase the airflow much as its NA (no turbo) so if you get excessive smoke then you would have to go back to the oem ones. If not, then hey presto, more grunt. The standard injectors don't make smoke so all the available fuel is getting burned....if the next size up makes little or no smoke then happy days, you will get more power without failing an MOT smoke test - but check under load and at full revs just to be sure (when engine is fully warmed up) - breakers yard is a good source of injectors or ebay.
Alternatively find the max-fuel screw on the injection pump and tweak it for max power output with acceptable smoke output i.e. when it smokes, back it off slightly.
More fuel = more grunt on any diesel, its just a question of finding the sweet spot when almost all the fuel is burned with a teeny bit of smoke left over.
Hope this helps, just my tuppence worth. I'm more used to tuning vw/audi tdi's cos thats easy Smile
  • Ol'Jeffers
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
