  • 9 Vote(s) - 3 Average
What type is the connector on the stereo?
Hi,
I've a 2010 1,6 diesel.
I bought a bluetooth device that I'm supposed to connect between the stereo and the wires to the car. The bluetooth device has ISO-connectors, but the connectors in my car seems foreign to me. I've attached some images. Does anyone know what this connector is, and can I get adapters for it?
reg
Svend
[Image: vospyt.jpg] [Image: 16kopxd.jpg] [Image: 23mlpvt.jpg]
may be wrong but i think its can-bus mate - dunno where you would get an adaptor for that.
Thanks for answering, but I don't think it is. It's a combination of ISO, cd-changer and something else.
(17-06-2012, 01:07 PM)Zion Wrote:  may be wrong but i think its can-bus mate - dunno where you would get an adaptor for that.
To answer this question myself Smile
I found an adapter which will make you be able to connect a device with ISO plugs: http://www.amazon.co.uk/dp/B003Q8XN8O/re...TE_3p_dp_1
[-] The following 1 user says Thank You to Doownek for this post:
  • brodfather11
Why not just replace the original radio? I have done This in my berlingo,
Fitted an alpine With Bluetooth and steering remote control.
But You got the right Cabel There. They have it on
http://www.bilradiospes.no
http://Www.bema.no
Strange that You dont have Bluetooth factory mounted in your radio since it's a 2010
Send me your vin number in pm and i can check if You want.
Thank you for answering.
Which radio did you change to, and what did you do to make the steering remote work?
Where do I find my vin number?
(02-02-2014, 12:52 PM)Tikki Wrote:  Why not just replace the original radio? I have done This in my berlingo,
http://Www.bema.no
Your vin number is on the bottom right side of your wind screen if your look from the front all so in your log book
  • Doownek
http://www.bema.no/?ItemID=9056
http://www.bema.no/?ItemID=7604
I had theese in my car alpine, and interface.
PS the interface is exprencive. So look on ebay or buy 2'nd hand.
Now i have This in my work van,
and i have installed a 2din multimedia player in my private berlingo With rev/cam.
Your vin is where Jed Clampit says.
Or You can type in your licence plate numbers here, and You will see UNDERSTELLSNUMMER/VIN
http://www.vegvesen.no/Kjoretoy/Eie+og+v...trollfrist
[-] The following 1 user says Thank You to Tikki for this post:
  • Doownek
(05-02-2014, 06:14 PM)Tikki Wrote:  http://www.bema.no/?ItemID=9056
Is the Alpine connectors just ISO?
Can I use this: http://www.amazon.co.uk/dp/B003Q8XN8O/re...TE_3p_dp_1 (which I already have)?
the alpine player just have regular flat iso connectors. so you need something like the cable loom you have linked from ebay.
but if you want the remote controll on the steering coloum to work you need this kit http://www.bema.no/?ItemID=9056 the big black box is the interface that controll the remote on the steering coloum.
  • Doownek
sliding door panel removal
Last Post: mojito
23-03-2025 07:35 PM
XL tyres
23-03-2025 06:57 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
22-03-2025 09:52 PM
Rumbling Noise 55-65mph
22-03-2025 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
