  • 10 Vote(s) - 3.4 Average
Torque Setting
Hi All,
I have fitted a new front coil spring but my manual has not arrived yet. Can anyone supply the torque settings for:
Drive shaft nut
Steering ball joint
Anti roll bar joint
Brake caliper bolts
Many thanks
Hi Green Monster
1. 320nm
2. 35nm
3. 40nm
4.27 nm
Regards,
Griff
Landmark
Ex 1.4 Berlingo Multispace
320nm?
Many thanks. 320Nm seems high, this explains why I needed to use a long extension on my socket set to undo it. Should have the MOT passed tomorrow.
Hi GM,
Re drive shaft nut. I assume you mean the large nut under the lockingcap secured with "R" clip. If so that's the correct setting according to the Haynes manual.
Griff
Landmark
Good luck getting it to 320nm
Leaking windscreen or aerial
Last Post: Guanajuato
Today 09:05 PM
Apple Carplay
02-04-2026 01:26 PM
