  • 8 Vote(s) - 3.5 Average
Blooming Drivers Seat base.
Dam foam seat base is giving up the will to be a seat again, :brickwall:replaced it with a new one 70k miles ago, but splitting again. Cost 50 quid last time for a new one any know if its still a stock part or special order? and any idea of cost, good thing only just over 30 mins to fit as I changed the hog rings for cable ties, that trick works a treat.Big Grin
This is what you are looking for:-
0000890659 CUSHION PADDING 87.47 GBP 104.96 GBP 104.96 GBP
£50 last time looks a bargain !
Yes looks that way, pick up a brand new lucas pump at the same time brand new still wrapped for £49, both from a stealers over Rugby way. Thanks for the part number.
I swapped over the passenger one instead
yep thought of that still leaves a bum seat in the car, for passanger so your no farther forward
(27-06-2012, 07:38 AM)squaddie Wrote:  yep thought of that still leaves a bum seat in the car, for passanger so your no farther forward
Hi I know you have already replaced a seat base(foam) but I did a write up, Drivers seat repair M49, in the how to section. and I put some tips for smoothing the seat frame and reinforcing the foam which may help. My repair is up to 120,000 miles now & still holding. Hope you can get it sorted.Confusedcratch:
Thanks for that will have a look and see
Mine is still on the original seat at 140k just what do you guys do to them?
Sod the passenger, i'm the one doing the driving LOL
Know someone who works at Carpenter, who produce memory foam and furniture foam. Might see if next time get a piece from them a stuff the seat with it.
Mileage
Today 04:33 PM
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
