  • 17 Vote(s) - 2.59 Average
Wet Bsi unit
Hi all hope you all can help me? I've got a Berlingo van 03 reg 1.9 non turbo.my Bsi unit got wet and now it won't start:brickwall: can I buy one of eBay and put in??? Help me thanks
have you had it out of to try and dry it out also if you have and put it back in did you follow the bsi reset procedure.
Personally I wouldn't buy anything that specialised second hand from eBay.
If you get a faulty one you won't know!
I would get mine checked and if necessary repaired by this company:
http://www.bba-reman.com/content.aspx?co...ol_failure
They do an exchange service as well. Ring them to find out how much they charge.
I have had it out to dry it,then I put it back in then all the dash lights all on and head lights on with the key out??how do you do the Bsi reset procedure ?
(26-06-2012, 10:12 PM)W2yne Wrote:  I have had it out to dry it,then I put it back in then all the dash lights all on and head lights on with the key out??how do you do the Bsi reset procedure ?
click on the link and the reset procedure is on there
[-] The following 1 user says Thank You to BerlingoHDI for this post:
  • W2yne
You can not fit a second hand BSI unit unless its been virginised.
You will have to fit ECU,BSI & Key Antenna as a matched set if fitting second hand.
You must also ensure that the doner vehicle is exactly the same spec as your vehicle - i.e does it or yours have rain activated windscreen wipers- if you don`t the BSI won`t hibernate !
You might be able to use one of the two circuit boards out of a second hand BSI in your BSI Unit ( Not the PCB with the main processors on it) do a search on here i think someone did this a while ago.
2003 Citroën Berlingo 2.0HDi Multispace Desire
(26-06-2012, 10:02 PM)W2yne Wrote:  Hi all hope you all can help me? I've got a Berlingo van 03 reg 1.9 non turbo.my Bsi unit got wet and now it won't start:brickwall: can I buy one of eBay and put in??? Help me thanks
I have same problem did you get it sorted?:brickwall:
Unlikely that you'll get a reply as the post is nearly two years old!
Try starting a new thread with your engine type and year....that'll work!
Crankcase pressure reference values?
Last Post: saskak
Today 10:59 AM
1.6hdi 2008
Last Post: cancunia
Today 08:34 AM
Replacement TPS Sensor
Today 07:16 AM
Juddering when pulling away
Yesterday 07:33 PM
Can’t find where to plug fault code reader in
Last Post: Gadgetman
Yesterday 07:22 PM
Titsup
Yesterday 07:18 PM
Aux cord functionality
Last Post: Lighty
Yesterday 05:50 PM
2.0 hdi abs no communication from abs ecu
Last Post: cancunia
Yesterday 02:15 PM
Steering column play
Last Post: Stevjoe
Yesterday 10:05 AM
Steel wheels wanted
Last Post: Art b
Yesterday 09:59 AM
