  • 24 Vote(s) - 2.83 Average
Intermittant binding front OS brake...
Pedal goes stiff and the need to use the handbrake is negated.....
It was raised by Nationwide when it went in for MOT last year, so they did a brake service (whatever the hell that is, probably take the pads out, add copperslip and refit for a guess)
However, the issue has returned....
Has anyone else experienced this ?? ( the binding, not the brake service - lol )
53 plate 1.9d Multispace Forte
Upgraded t'wireless and front speakers, loads more planned but not much action.. Wink
so pedal goes hard and front brakes are useless?
the brakes are working fine, just that the pads are not releasing on the front OS disc...
but it is intermittent, which is what is confusing me Sad
i suppose first thing is get the caliper off and take a look at the condition of the pots, see are they moving freely
[-] The following 1 user says Thank You to corkgsxr for this post:
  • Grimsqueaker
I would check the calliper maybe try using a "G" clamp and winding the pistons in and out a few times, you need to check the pads have not overheated if they are worn I would replace them anyway ,if the calliper piston is tight/seized you may have to replace the calliper, if you are not sure best get a local garage to check it over.
[-] The following 1 user says Thank You to jimbo for this post:
  • Grimsqueaker
thanks guys
fingers crossed we will get some pleasant(ish) weather soon, and I will be able to investigate further
(20-02-2011, 07:57 PM)jimbo Wrote:  I would check the calliper maybe try using a "G" clamp and winding the pistons in and out a few times, you need to check the pads have not overheated if they are worn I would replace them anyway ,if the calliper piston is tight/seized you may have to replace the calliper, if you are not sure best get a local garage to check it over.
why not rebuild it with new seals and pot (if damaged)
If the slave cylinder and caliper are moving in and out freely, then check the flexible pipe leading to the cylinder. They can deteriorate inside so the fluid doesn't flow back when the pedal is released (thereby maintaining pressure within the cylinder and causing the brake to remain on).
I've known this to happen on 2 cars, not being immediately diagnosed and costing each unfortunate driver a new wheel bearing through over-heating.
'07 Berlingo Multispace 1.6i 16V Desire 5dr in Iron Grey
Three things worth checking,
See if your brake caliper/ wheel cylinder has seized
Check the handbrake mechanism is not incorrectly adjusted
Your master cylinder may be faulty.
Not sure how handbrake adjustment is going to have an effect on the operation of the front OS brake...
I think, from the responses, that the most likely options are caliper issues OR brake line....
Could corrosion on the guide pins or bolts have an effect...
triangle light
Last Post: norm1
Today 12:20 PM
Yesterday 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
