  • 10 Vote(s) - 3 Average
start / stop
Hi i hope someone can help please.
I have a 1998 berlingo non turbo no power steering no central locking.
The problem I am having is the beep for key kept going and it would not stop even with the key in and the van would not start.
The AA man came and pulled a few fuses out and said he had reset it.
After lots of messing and head rubbing it started then the beep started again .
Rather than risk turning it off I turned up the radio and carried on.
Got home and switched it off.
The beep went and the van started again no problem.
I switched it off and removed the key but the engine still ran and the Speedo read 60 mph.
I put the key in again and after a few on / offs it switched off.
Then I tried again and it ran on again.
I reversed a bit and when I put my foot on the brake the engine shut off.
I put in the key started it up switched it off and the engine ran on so I tap the brake and the engine shut off.
Any ideas please
:brickwall:
(01-07-2012, 06:50 PM)mikeprice Wrote:  Hi i hope someone can help please.
Any ideas please
:brickwall:
Beep for the key????..
Does the engine turn over when it doesnt start. ?
Main earth wire on the engine to body earth ok?
It could be other earth wires faulty. for when you touch the brake pedal it must be stopping the feed to the fuel solenoid, the speedo showing sixty may mean an voltage through the speedo head which is trying to find an earth
check the battery connections , it only takes 1 small wire to corrode through to cause big problems.
dont think yours has a BSI so a Bsi reset wouldn't work.I think I read about bad earths on the forum but I cant seem to find them Confusedcratch:
Any ideas please
:brickwall:
hi
Thanks for the reply.
It used to beep if the key was left in and the door was open.
I will check earth leads. Watch this space .
Cheers . Mike
Yesterday 10:15 PM
» Replies: 41
What is this?
Yesterday 07:23 PM
Iceland Trip and modifications
Last Post: Vantour Berlingo
Yesterday 06:05 PM
Engine judder at 1800 rpm
Last Post: rodthemod
Yesterday 04:58 PM
Heater blower not working
12-09-2024 12:22 PM
Key.... repaired... but how much for a New fob
Last Post: Gadgetman
12-09-2024 08:19 AM
Correct FAP Tank? 2012 plate L2 van
11-09-2024 11:34 AM
High Beam LED upgrade possible? YES
10-09-2024 10:31 PM
ABS Sensor Fault M59 1.6HDI
Last Post: BaysideM59
10-09-2024 08:42 PM
Knocking sound from front end when going over ro...
Last Post: markscotford
10-09-2024 08:04 PM
