Threads: 23
Thanks Received: 24 in 15 posts
Thanks Given: 11
The piece of string with a bit of plastic on each end that unlatches the seat base when back is folded forward has broken:whistle: at the seat back end. Has anbody here made a repair or is the part easily available from the main stealer, I have not tried there yet.
Threads: 9
Thanks Received: 31 in 26 posts
Thanks Given: 8
Never bothered fixing mine, just pull it by hand when folding/unfolding the seats. Sort of assumed it would just break again if fixed. Would be happy to be told otherwise!
Threads: 52
Thanks Received: 82 in 67 posts
Thanks Given: 9
I have never noticed a "piece of string" anywhere. I just press the button on the top of the seat. The back then tips forward, and if wanted, the back and the base can pivot forward together. How does the "string" come into play? Can someone take a picture?
Threads: 50
Thanks Given: 743
12-07-2012, 12:31 PM
(This post was last modified: 20-07-2012, 04:36 PM by Ol'Jeffers.)
EDIT: Apologies....just me talking rubbish as usual! Take no notice!
Yes! Photos of this piece of French hi tech equipment would be a bonus!
Threads: 63
Thanks Given: 410
(11-07-2012, 07:53 PM)Husqyman Wrote: The piece of string with a bit of plastic on each end that unlatches the seat base when back is folded forward has broken:whistle: at the seat back end. Has anbody here made a repair or is the part easily available from the main stealer, I have not tried there yet.
I did a write-up elsewhere on the forum about this and was going to make one but they are only about £4.00 from main dealers so hardly worth the time and effort. From memory the hardest bit was getting the bits of sheared-off plastic out of the seat back and squab but about a 5 minute job to do... easy-peasy..
Threads: 9
Thanks Given: 8
Um, mine's a Mk 2 and has them too. They connect the seat back to the big metal hooks which hold the back of the seat base down, so that when you fold the seat back down the string gets pulled and the hooks get pulled out of engagement (they're spring loaded).
If they're not broken it works just as Chris has described.
If they are broken, you'll see a bit of string (maybe five inches long?) around the back of the seat base (one each for the left and right bits of the rear seat) - just pull them up to release the seats.
Girlfriend has the car today else I'd take a photo.
Threads: 52
Thanks Given: 9
All clear and understood now!
Threads: 28
Thanks Received: 13 in 13 posts
Thanks Given: 7
you can see then when they're intact, just easier to see them when they are broken.
MK1 Berlingo, Y-Reg 1.4 Petrol Now LPG Converted.
