  • 8 Vote(s) - 2.13 Average
wiper question
When I switch on the windscreen wipers after starting the engine the rear wiper operates for a few times then stops, sometimes for a longer duration than others. The rear switch is set to off. Is this a normal feature or is it the Herbielike personality coming out again? Confusedcratch:
Anyone experienced this? Confusedtudy:
Probably unlikely, but you are not in reverse gear are you??
[-] The following 1 user says Thank You to tucker for this post:
  • mrbritse
Mine has done this on occasion when it's raining. Sometimes the rear wiper comes on for a few wipes by itself (although switched off) when it starts to rain. Not often enough to worry about.
[-] The following 1 user says Thank You to 3rensho for this post:
  • mrbritse
Strangely....mine too!:eek::thumbsup:
  • mrbritse
My Clio used to do that.
And if front wipers were on, rear came on when you select reverse.
[-] The following 1 user says Thank You to j90xxx for this post:
  • mrbritse
(12-07-2012, 09:28 PM)tucker Wrote:  Probably unlikely, but you are not in reverse gear are you??
Well yes, I guess I am, didnt think about that but it is when I reverse out of the drive I notice it. Can it be that?
my skoda does that , helps to see when reversing in the rain.
they are designed to come on when you are in reverse when the front wipers are switched on
[-] The following 1 user says Thank You to BerlingoHDI for this post:
  • mrbritse
(13-07-2012, 01:52 PM)j90xxx Wrote:  My Clio used to do that.
My Berlingo does that,it's supposed to.
  • mrbritse
A case of RTFM? Oops. Confusedillyme: Confusedtudy: Confusedalut:
M59 unlocking itself
Yesterday 04:06 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
31-10-2025 03:06 AM
» Replies: 40
